Resize pop-up depending on screen resolution
Hello all,
I have read a lot on here but never posted anything. This time however I am not sure if it is me or maybe a bug so therefore this post hoping someon can help me out. I have a pop-up with two alarm tables. I want to open the pop-up in different resolutions and to scale what is inside the pop-up. I managed to change the width and height of the pop-up. I have two parameters and bound them to props.width and height of the pop-up. I have another pop-up and this scales perfectly. however the alarm tables only resize after I resize the pop-up a little bit. I want the pop-up to look like this:
But when I have a smaller screen the initial result is this:
Draging the pop-up to resize results in the tables both sharing and filling the screen. I set them both to basis 50%. I know this is not exactly what they are but it works for a big screen. I am using a flex container.
Solutions tried:
  • refresh binding on startup script with a property on the tables
  • Add margin in on startup script hoping to force a resize
  • Changed the view to a Coordinate container (same result)
  • Ask AI (rubish)
  • A new flex container with two alarm tables this time no other settings but the 50% basis.
So I am at a loss. especially since I have another pop-up which does work and this has the same configuration.
You can pass height and width parameters with the position arg in system.perspective.openPopup. With the proper container settings, you can skip the parameters and bindings for sizing.
position = {
    'height':'30%', #or pixels
    'width':'60%'
system.perspective.openPopup(
    id,
    'View',
    position=position
Do you have your table columns set with strict width?
I would expect the container settings as follows
Thank you! I am going to buy a new pair of eyes. I completely missed this. The percentage solution worked! Now there is only a strange wite field at the header.I think it is because the slider on the right doesn't scale with the table.
I tried to use webkit-scrollbar and got my scrollbar to work correctly but I can't seem to get the wite square to go away.
