I have a component on one of my templates that I don’t want to resize when I expand it in a normal window. I assume I would use a script just on that one component but haven’t had any luck so far.
Thank you
Thank you
You need to enable layout on the root of the template, and use anchored layout on your component
What if I want everything else in the template to be resized except for that one componant?
I can’t recall, but does setting the other components to relative layout not do this?
I had to ungroup them first and uncheck ‘maintain aspect ratio’ but it finally worked. Thank you!
