Resolution post: Connecting to Siemens OPC UA Server for WinCC Panel RT (TP700)
This post is a resolution:
This is my scenario:
  • I have a Siemens HMI TP700 which has the OPC UA server (not the S7-1200 PLC)
  • There is a Scalance (Siemens managed switch: Scalance XC208) connected from the HMI and PLC to translate the local IP addresses (PLC: 192.168.100.103, and HMI: 192.168.100.102 into our organization's IP addresses (HMI: x.x.x.x)
  • The goal is to connect the OPC UA server to Ignition using our translated IP address from the HMI by the Scalance. This IP address is again (not the local IP but...) our organization's IP address.
  1. The first step is to configure the settings in the HMI for enabling the HMI OPC UA server and enable the "Use router" to be able to ping the HMI via the Scalance:
    1.1 Ensure that the highlighted boxes are checked:
    Note: the “None” box has to be checked for me to browse the tags (see the screenshot below): Reference: page 12 on this document: https://cache.industry.siemens.com/dl/files/236/63481236/att_917850/v2/63481236_Part4_Panel_Server_und_OPC-Scout_Client_en.pdf
    1.2 Ensure that the "User router" box is checked:
  2. The next is to configure the Scalance:
    2.1 The managed switch has a total of 8 ports: 4 ports (1-4) will be configured for vlan1 and the other 4 ports (5-8) will be configured for vlan2.
    2.2 Configure the Scalance IP address using the SinecPNI software:
    Give it an IP address belonging to your organization's network
    2.3 Layer 2 Configuration: Internal (INT) and External (EXT). Set the vlan1 to be EXT (because it will be translating the IP address from the INT) and vlan2 to be INT. This way ports 1-4 are configured for the EXT and ports 5-8 are configured for the INT.
2.4 Layer 3 Configuration:
Configure the Inside local address to be the address of the HMI (because the HMI has the OPC UA server).
The Inside Global Address to be the IP address of your organization.. and this will be the IP address of the OPC UA server (translated IP from the local HMI IP) to be used later for connecting to Ignition. Note: To change these IP addresses, you may have to delete the entry (by checking the box) and then create the entry again:
2.5 Check the configuration for vlan1:
Vlan1 must have the IP address of your scalance:
2.6 Check the configuration for vlan2:
Vlan2 must have the router/gateway IP address of the local HMI (in our case it will be 192.168.100.1
2.7 Check the configuration for vlan1 and vlan2 in the Overview: Note: remember vlan1 must have the Scalance IP address and vlan2 must have the router/gateway IP address of the local HMI:
2.8 For the Default Gateway, enter the router/gateway IP address of your organization (automation) network:
2.9 Lastly, we just check the idle timeout:
  1. Make the connection with Ignition
    3.1 When setting up the connection in Ignition, the port must be 4870
    Also for reference, check page 11 on this link:
    https://cache.industry.siemens.com/dl/files/236/63481236/att_917846/v2/63481236_Part2_Panel_Server_und_RT_Adv_Client_en.pdf
    3.2 One important thing is that after attempting to connect to the Siemens HMI OPC UA server, the connection is going to be faulted in Ignition. Why? Because the OPC UA server will generate a certificate and its system will place it into a "Reject" folder. So what you need to do is to get into the HMI OPC UA server Windows system, cut (not copy) the certificate from that "Rejected" folder and paste it into another folder named "Certs". For reference, check out the following link on page 15: https://cache.industry.siemens.com/dl/files/236/63481236/att_917846/v2/63481236_Part2_Panel_Server_und_RT_Adv_Client_en.pdf
    After that cut and paste of the certificates, you should get a fully connected connection between Ignition and the Siemens HMI OPC UA server.
    3.3 If you cannot browse the tags in the Ignition OPC client, do the following: Per this Forum post, change the Max per Operation property in Advanced to 64. Change it from the default value of 8,192 to 64.
Apologies for posting in an old thread but I'm desperate...
I just came across this post after extensive search trying to troubleshoot the problem I am facing. I am trying to connect to Siemens WinCC Comfort Panel's OPC UA server. So far, I've managed to connect to the server, and after changing the Max per Operation value to 64 I am able to even browse tags. My Ignition version is 8.1.47-trial.
WinCC panel is third party and something I will struggle getting into and changing setup especially with all working OK in UAExpert.
Before I changed value of Max per Operation to 64 I had numerous errors in logs all saying "Error decoding UAResponse message".
After changing to 64 I am getting the same error messages in logs as well as "[id=3] expected sequence=35, received sequence=36. Calling Republish service..." and "Uncaught Throwable during execution."
When I subscribe to a single tag, I get "Uncertain_InitialValue".
Needless to say, UAExpert is connecting and displaying values, no problem.
I am running out of options and could do with any kind of help anyone can offer.
Thank you in advance.
Aleksandar
Provide Wireshark captures and logs (make sure to turn off security for the connection), we'll see if there's anything that can be done. The WinCC OPC UA server has been notoriously buggy over the years.
UaExpert is hardly representative of the behavior of a "real" client. You connect, it does nothing - doesn't browse/read the datatypes, doesn't read the type dictionaries or datatype definitions, etc. You click around and it's issuing one request at a time for one node at a time. It barely does anything in bulk except create multiple monitored items if you drag/drop multiple. Meanwhile a "real" client is going to do all these things, it's going to bulk create subscriptions / monitored items on startup, it's going to have multiple publishing requests going, keep alive requests, writes from your application, etc. It's just very different.
Hi Kevin. Thanks for the reply.
I've never used wireshark before and I might struggle. What will I try to capture, responses from HMI?
Regards,
You should probably work with support in that case. You need to capture OPC UA traffic between Ignition and the panel. You would run Wireshark on the same server/PLC that the Ignition Gateway is running on.
OK, I'll try that. It's been some time since i used it last time.
I see your point on the UAExpert, very fair point.
Regards,
Just to let you know, I did manage to get the equipment manufacturer to update the siemens panel's firmware to the latest one and everything started working. Logs are gone, and I can read all tags without problem.
Thank you for the help!
Regards,
