Hello,
We have a module developed for Ignition version 7.7.x and need to make some updates now.
While using module_showcase project for signing the module, getting error as below -
API Call failed. Server returned HTTP response code : 500 for URL https://api.inductiveautomation.com/authenticate
Is there a change in the API recently ? Is anyone else facing a similar issue ?
Appreciate help in this regard.
Thank you !
https://api.inductiveautomation.com/authticate
authticate instead of authenticate is likely the reason for the 500 error.
https://api.inductiveautomation.com/authenticate should work for you
@Samir_Nileshwar , Thank you. Sorry about the Typo in the post, however URL I used was the correct one. Have edited the post.
I am using the module_showcase Ignition project.
Below is the screenshot of the error
Any pointers ?
Thank you.
So, not a problem with signing, but with authentication to get the Session ID. You should double check your credentials.
Thank you, @pturmel , this was an issue with module showcase account. Got this resolved with the help from IA Support.
showcase ignition project Where can I download it, or can I have it
