HI,
I have a module that I have been adding expressions to, I have now added a scripting function to it, it all builds fine, and works correctly, however when you get the help pop up when selecting the function in a script it all shows blank or null values.
Looking in the target folder after the build the properties file is going into the wrong directory.
I have created the .properties file in a matching folder to the class path, however when built it goes into the same level as the com folder.
the directory of the .properties is src/main/java/resources/com.company.ignition.expressions
the class path is src/main/java/com/company.ignition.expressions
any ideas? I have scoured the pom.xml files for any indication of where it puts resources but I cant seem to see anything. The example on git builds to the correct place, but I cant see any differences.
I just actually created the path rather than typing it in and its worked, simple in the end, just a couple of hours I wont be getting back
