I am trying to install OEE module but i’m getting following error
Response from 127.0.0.1:10000 is error.
Regards,
Talha Riasat
Regards,
Talha Riasat
Which version of Ignition are you using?
It sounds like a version incompatibility issue.
If you are using Ignition 7.3.x, the OEE module can be installed by selecting “Let me choose the module to install” when running the Ignition installed.
If you are using Ignition 7.2.x, you will have to download the appropriate OEE module from the archives by selecting 7.2.9.
