Restarting Ignition Gateway
I am debugging a faulty database connection and it has been recommended that I restart the Ignition gateway.
Can I do this without losing tag data? I have created a backup of my Gateway just in case.
Is this the correct command for a Windows system?
gwcmd.bat -r
You won't lose any tag configurations, but any Vision clients/Perspective sessions using those tags for display will error while the gateway restarts. If your database is for tag history, you'll also have a history gap for this period.
Your command looks right, though you might need .\gwcmd.bat -r depending if you're using powershell vs command prompt (I think?)
You can restart the service in services.msc since it's a windows system.
