Restore application
I was working on standalone application and the computer crash.
I was able to recover the the hard drive but not the computer.
It is it possible ot restore project by the files I can find in the hard drive?
Thanks for all.
Was the computer running an Ignition Gateway? If so, you can navigate to the Ignition installation folder, then to data/db. Copy all files inside the /db folder somewhere else. Install Ignition on another machine. After Ignition is installed, shut down the Gateway. On the new machine, navigate to the Ignition installation folder, then to data/db. Delete everything in the db folder, then copy over the files that were in the /db folder from the old hard drive. Start the Gateway. After the Gateway is running, your projects should be available.
Thanks.
It working…
