Is it possible to restore local gateway projects after done PC reformat. Because I forgot to backup my latest projects and did not enable the auto backup in gateway settings, because my PC accidentally encountered fatal error, so I reformat it, and after that I installed Ignition again and all of project was gone.
Well, if you reformatted the drive, then you’re pretty well hosed.
Ignition does still make it’s own backups internally that can be found at {Install Dir}\contexts\main\db\autobackup that can help you get out of a jam, but you would have had to grab those before reformating.
Hi Jordan,
I forgot to take a backup of my gateway backup when I restored another Gateway and lost old project and gateway backup.
Is there anyway I can have my old project and gateway? ( Else I have to do my 3 days work again).
