Restoring data for a wrongly deleted tag
My customer wrongly requested that I delete a tag and now wants it restored.
Using a gateway backup, I exported and then imported the required tag back into Ignition. I have updated the sqlth_te table so that this tag’s retired value is returned to NULL.
I can assign the tag in the ad hoc chart, but I cannot see any of the historical data that was captured. What do I need to do to resolve this?
Check sqlth_te for duplicates. The most likely explanation I can provide is that a new entry was added, and is the one used.
When you edited the table, it made no difference as the cache was still showing a retired tag entry at this path and a new one was created.
When you manually edit the historian tables, make sure to restart the history provider to make it rebuild its cache.
Hi Pascal, thanks for the feedback. Yes, you were correct, there were two entries in sqlth_te with the most recent entry generated from the recent import.
I have deleted the latest entry and restarted the historian, but still, no historical data is available. Do you have any further suggestions, please?
There's a chance tags have a hidden, internal id, and that it doesn't match.
But that's way out of my knowledge, you'll have better answers from someone else (most likely Paul or Phil).
I kinda wish you had not deleted the latest entry yet. You should have checked some of its meta data first, following the scid -> drvid trail.
For now I guess you can check what happens when your tag gets new data: Is that data sent to the current entry in sqlth_te ? Or is a new one created ?
Thanks for the follow up Pascal. Unfortunately it was not my decision to delete the tag. I have a gateway backup from prior the tag deletion, would that hold the information you are referring to? If so, where do I find it?
Also how can I get in touch with Paul or Phil? This is starting to get desperate to resolve.
This is not a forum topic at this point, you should be calling IA Support and handling it through the official support channels. This is a volunteer forum, and while we endeavour to help, the moment you mention a level of desperation or a timeline, this is not the place to be reaching out.
I’d love to reach out to IA for support, but correct me if I am wrong, this this a paid service? If so, then I don’t have access to this level of support.
Never mind, I have found a link to the IA help centre.
Support plans are normally attached to the License Key on the customer gateway.
If you have not kept the support plan current, then this is a commercial issue that you or the customer needs to deal with.
I am just indicating that here on the forum, nobody should be put under pressure to resolve your issue with any wording that suggests a timeline or a desperation level, because nobody here is responsible for your project. We will try our best to help, but if it is urgent or business critical, there are paid support avenues that will cover that need.
