Hi
I have a project that’s setup on a 8.0.2 ignition gateway. There are buttons on that project that targets to other projects on different gateways. I have older projects that’s on a 7.8 and 7.9 ignition gateway, when I try to navigate to those using system.util.retarget I get this error:
Is this possibly a version issue? Like util.retarget only works if the project/gateway im redirecting/switching to is on the same version.
Is there an alternative I can use other than util.retarget so I can switch to other projects that’s on a different version?’
Thank you
