Say I have a custom property on a Perspective view that has an indirect binding. I’d like to retrieve the “result” of this indirect binding in an expression. Is this possible?
Here is a more concrete example, just in case I’m not phrasing that question well enough. I have a view that has a boolean custom property. This custom property is bound to a boolean OPC tag via an indirect binding. I would like to reference the tag that view custom property is bound to in an expression binding on a component’s property. Is this possible? If so, how would I accomplish this?
The quality of the property should be the quality of the tag, if it’s using a tag binding with no other intermediaries. Does {path.to.property.quality} work?
It’s not working unless I’m doing something else wrong. I’m binding a label’s text property to the expression: ToString({view.custom.myProperty}.Quality) and I’m getting a config error stating that period is an illegal character.
