I am storing a short date value in my MSSQL database but this value is returned as datetime type from my named query. This becomes an issue when dealing w timezones west of me - the EventDate column dispays as the previous day to them. A simple way around this is converting my EventDate column to a string but then I lose table formatting on the Ignition side . I can live with that solution I guess unless someone has success returning a short date value?
Java doesn't have a date type without a time component. JDBC has no choice but to apply the DB connection timezone to produce a java object.
Your only solution in a multiple timezone application is to use UTC datetimes everywhere, or use data types that are inherently timezone-aware. Java defaults to the latter.
Ignition will be happiest if you always deliver DateTime2 through JDBC. Consider using views to CAST() where needed if DB redesign is too much trouble.
