Hello, I have nginx running in a docker to act as a reverse proxy for a currently functional Ignition.
I access the home page correctly, but when I press login it incorrectly redirects me to an undefined page.
The nginx configuration file is as follows
events {
http {
# Bloque para redirigir HTTP a HTTPS
server {
listen 80;
server_name localhost;
# Redirige todas las solicitudes en HTTP a HTTPS
location / {
return 301 https://$host:444$request_uri;
# Bloque para manejar HTTPS
server {
listen 443 ssl;
listen [::]:443 ssl;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
underscores_in_headers on;
# Certificados SSL
ssl_certificate /etc/nginx/certs/domain.crt;
# Ruta al certificado
ssl_certificate_key /etc/nginx/certs/domain.key;
# Ruta a la clave privada
# Configuraciones recomendadas para SSL
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
location / {
proxy_pass http://10.230.201.10/data/perspective/client/CROM/;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host:$server_port;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass_request_headers on;
proxy_cache_bypass $http_upgrade;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Port $server_port;
location ^~ /data/ {
proxy_pass http://10.230.201.10:80/data/;
location ^~ /system/ {
proxy_pass http://10.230.201.10:80/system/;
location ^~ /res/ {
proxy_pass http://10.230.201.10:80/res/;
location ^~ /idp/ {
proxy_pass http://10.230.201.10:80/idp/;
location ^~ /.well-known/ {
proxy_pass http://10.230.201.10:80/.well-known/;
# # Configuración para la ubicación /crom
location /crom {
# location /sotrweb {
# proxy_pass http://10.230.201.10/data/perspective/client/BLC_WEB/welcome/;
# proxy_http_version 1.1;
# proxy_set_header Upgrade $http_upgrade;
# proxy_set_header Connection 'upgrade';
# proxy_set_header Host $host;
# proxy_set_header X-Real-IP $remote_addr;
# proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
# proxy_pass_request_headers on;
# proxy_cache_bypass $http_upgrade;
# proxy_set_header X-Forwarded-Proto $scheme;
# proxy_set_header X-Forwarded-Host $host;
# proxy_set_header X-Forwarded-Port $server_port;
