How can I revert a resource that is unpublished, back to the published version?
Cheers
Cheers
Maybe there’s a better way, but if you go to the web page and export the project, you can choose to export the staging or published.
Choose published, then in designer import the window you want from the published.proj file.
Thanks, this does the trick, but yes, definitely could be made simpler!
