Good morning,
I'm trying to use the ribbon chart resource (Ignition Exchange | Inductive Automation) but I have an Xaxis issue as in picture
As you can see the time in the tooltip is correct but the Xaxis labels are showing wrong values, to be precise the labels have a 30 minutes negative offset.
What could I check to fix this problem?
Thanks for the help
