Thought this would be simple…how to I right justify text in a Label?
- Right-click the Label and select
Customizers > Style Customizer. - Select Data Quality as the driving property (although you could set your own custom property to driver this if you’d like).
- Select “Horizontal Alignment” as the Styled Property.
- Click the
+button in the lower right of the window to add a new style. - If you leave the value as 0, then this style will be applied while your Label has a
Goodquality. - In the Preview area, use the dropdown to select an alignment value which suits your needs.
In this screenshot, I’ve used Data Quality to drive the appearance, but I could also have used my alignment custom property.
I’m deleting the two replies about the anchor problem because it’s not an anchor problem, it was a user problem
