after upgrading from 7.74 yo 7.8.1 when in the designer and you try to edit a script on any component four error boxes pop up with the below message.
What I found was our default security profile for the project does not have any roles setup. i added a dummy role to the profile and the error messages stopped.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Role Retreival failed.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:327)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:301)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$GatewayMessageTask.execute(PriviledgedDesignerTask.java:426)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$TaskThread.run(PriviledgedDesignerTask.java:328)
at java.lang.Thread.run(Unknown Source)
System Details
fpmi.client.memory.used=605.00
fpmi.client.memory.max=3641.00
fpmi.client.type=Designer
fpmi.client.version=7.8.1 (b2016012216)
java.vm.version=25.51-b03
java.vm.vendor=Oracle Corporation
java.vm.name=Java HotSpotâ„¢ 64-Bit Server VM
user.country=US
os.name=Windows 7
os.arch=amd64
sun.os.patch.level=Service Pack 1
os.version=6.1
java.specification.version=1.8
user.language=en
ignition.gateway.version=7.8.1 (b2016012216)
ignition.gateway.memory.used=6119.06
ignition.gateway.memory.max=6119.06
ignition.gateway.uptime=10 hours, 36 minutes, 41 seconds
ignition.module.com.inductiveautomation.alarm-notification=3.8.1 (b2016012216) - RUNNING
ignition.module.apachecommons=3.2.0 (b1) - LOADED
ignition.module.itext=5.1.3 (b0) - LOADED
ignition.module.math=3.3.0 (b0) - LOADED
ignition.module.mobile=3.8.1 (b2016012216) - RUNNING
ignition.module.xopc=3.8.1 (b2016012216) - RUNNING
ignition.module.poi=3.11.0 (b0) - LOADED
ignition.module.rept=3.8.1 (b2016012216) - RUNNING
ignition.module.com.inductiveautomation.serial-support-client=3.8.1 (b2016012216) - LOADED
ignition.module.com.inductiveautomation.sfc=2.8.1 (b2016012216) - RUNNING
ignition.module.com.inductiveautomation.sms-notification=3.8.1 (b2016012216) - RUNNING
ignition.module.ia.voice.en_us_salli=2.8.0 (b0) - RUNNING
ignition.module.help=3.8.1 (b2016012216) - RUNNING
ignition.module.fpmi=8.8.1 (b2016012216) - RUNNING
ignition.module.com.inductiveautomation.phone-notification=3.8.2-rc1 (b2016022218) - RUNNING
ignition.module.com.inductiveautomation.webbrowser=2.8.1 (b2016012216) - LOADED
user.country=US
os.name=Windows 7
os.arch=amd64
os.version=6.1
user.language=en
