Root Container Property in tag write code
I have a dynamic window that covers many of my sites. Each site has a communication check button that the operator can click to check communication and force update the most recent data. I am running into a problem.
When I try to execute this code…
[color=#0040FF]system.tag.writeToTag(“RTUevent.source.parent.RTUID/CommunicationInfo/Interrogate”, value)[/color]
I get this error…
[color=#FF4000]Traceback (innermost last):
File “event:mouseClicked”, line 8, in ?
IOError: Token PROPERTY_SEPARATOR found after property name.
Ignition v7.2.6-beta11 (b112)
[/color]
If you're trying to dynamically build the tag path based on a root container property value then you are going to have to concatenate everything together. Something like this:
system.tag.writeToTag("RTU"+str(event.source.parent.RTUID)+"/CommunicationInfo/Interrogate", value)
Dave,
Once again, you guys are freaking awesome. Worked like a charm.
Thanks!
