Root Node Path in Historical Mode is not filtering
I’m using a tag browse tree component in 8.0.9
In https://docs.inductiveautomation.com/display/DOC80/Vision+-+Tag+Browse+Tree Historical mode filtering is like:
[DB/ignition:default]machine_1/
In my case in doing the same but is not filter, Is this a bug or just a wrong configuration?
As you can see folder 2 keeps showing, why?
Try something like this:
[datasourceName:/:gatewayName:tagProvider][tagName]
Bringing this thread back from the void. If anyone comes digging like I did…the colons between the datasource name and gateway name fixed my issue. Thank you for posting this. Ignition documentation may be incorrect as it omits the colons? Not sure.
There has been an internal bug ticket filed for this behavior. The work around above of using the format [DatabaseConnection:/:GatewayName:TagProvider]FolderPath/ will work until that bug gets fixed.
