Rotate animation in perspective
Hi everyone, I would like to ask you how can I reproduce the same animation here Component Animation - Ignition User Manual 8.0 - Ignition Documentation, in Perspective.
I've tried going in the inner svg element and applying a rotate transform and then linking it to a variable but it isnt rotating the element correctly.
In general I need to understand how to make animations in Perspective.
In perspective you should use css instead of a binding.
You can write css in the projects stylesheet (if you run on one of the more recent versions)
Here's an example for you. This is just a symbol factory graphic I dropped in.
The animation is on element (2) which is the impeller blades, it uses IAs animation, you can change the speed with animation-duration
Fan.zip (16.2 KB)
