Can i set rounded corners on a rectangle in ignition 7.9.9? I don’t see the little drag circles.
Works here. If you’ve selected another drawing tool or the regular cursor, make sure you select the rectangle then click on the rectangle drawing tool again to get the drawing controls back.
Yes reslecting the rectangle tool did the trick, thx
