Hi, guys!
It’s very important, help please.
I have dataset with 2 columns: t_stamp and Value.
Then I export this dataset to Excel on my Desktop.
When I make an export from Designer all the values are good and have 4 numbers after comma (1,5234 and 5,2314).
[attachment=1]Designer.xls[/attachment]
BUT when I make an export from Viewer all the values stay rounded (1 and 5).
[attachment=0]Viewer.xls[/attachment]
Why it happens?
What version of Ignition are you using? By ‘Viewer’, do you mean the Dataset Viewer that pops up when you view the dataset property on say, a table? What steps did you take to get that dataset into an excel file?
I wasn’t able to replicate this in 7.7.7-beta1 in either an English environment or a French VM (in case the comma as a decimal separator was causing the issue), but I’m probably not doing it exactly the way you are.
Ignition 7.7.5 x64
I don’t know what happens but it is works fine now.
Here is the code, where dataset has 2 columns (datetime, float) and i need to add one more row before export to Excel with Summ of floats (diffLine):
csv = system.dataset.toCSV(resultDataset, 1, 1)
csv = csv.replace(’“date”’, ‘“str”’, 1)
csv = system.dataset.fromCSV(csv)
csv = system.dataset.addRow(csv,diffLine)
system.dataset.exportExcel(“d:\data.xls”, 1, csv)
