Row color on report table if, elif, else
priority=="Low"?"916AAD":priority=="Medium"?"F5E11B":priority=="High"?"EC8629":"E22028"
my expression is not working properly
followed the examples here
Looks correct... Are you sure priority is the key and it's not just a column in a larger key? like MyData.priority?
yes, its the "priority" key, im using the alarm journal query btw, I already said the data key on the table
Try adding '#' to the color values:
priority=="Low"?"#916AAD":priority=="Medium"?"#F5E11B":priority=="High"?"#EC8629":"#E22028"
thanks but I didn't work
Looks like priority is not evaluating to a string, you have to force it. This works:
priority.toString()=="Low"?"#916AAD":priority.toString()=="Medium"?"#F5E11B":priority.toString()=="High"?"#EC8629":"#E22028"
Hi! thanks for the solution, i see the problem, yeah the data type of the priority is different.
i hope there will be some data type column in data browser so its much easier to troubleshoot stuff like this hehe
