Is it possible to get a text string showing the path to (and including) the selected item in the Row Selector
I am generating a report from the row selector and would like to set the title to show the tree path used in the row selector.
Just some further details on thi ssee if its possible in the attached image of a tree structure with the selection show can i get a string with the following or similar value:
‘NP Tests (81)\Unknown (81)\Bead (27)\UCR20/5-NP (6)’
Either with or without the number of results at each level.
This string would be used on top of a generic report to show what data was selected to generate it.
Regards
Malcolm Bird
Swift Automation
UK
If I remember right, you should just have to put the selected path into a dataset. then use that dataset in the report.
The Row Selector does not appear to have a property ‘selectedPath’ or similar
Hi Malcom,
There is a selectedRow property. That tells you the row in the dataset. There is an item path column in the dataset. That is your path you are looking for.
Tried using selectedRow as a property but is not reconised for the Row Selector component
Any pointer to where i should look
Here is a sample project that has a tree control and two labels. When you select an item in the tree, one label shows the complete path, the other one shows the selected item index/row number in dataset.
test (2012-02-22).proj (11.6 KB)
Robert,
Thank you for the project, I have confuse you with the image I posted its not a Tree Control Im using it is the Row Selector from the reporting components tab, Although, this displays as a Tree it has a reduced number of properties available compared to the tree.
Appologies for my naming of the image…
I was wondering if that was the case when I created that project and noticed the selectedPath was a basic property.
No harm done. Sorry I can’t help you with the reporting module. Never used it.
Just a nudge on this topic if anyone has an answer or should I put this in as a feature request !
I think you need to post a feature request because the hierarchy is dynamic.
Will Do, Thanks Travis
Any further developments on this?
I need to do the same thing - want to generate a default filename for saving a report, based on what was selected using the Row Selector.
I’m only filtering on one item so it’s a simple setup.
I know I could look at the Data Out and pick out the relevant column to get the filtered value, however this wouldn’t work if All Data was selected.
(I thought about comparing Data In to Data Out to see if they were/weren’t equal but looks like Data In isn’t available as a property)
Ignition version 7.6.6
Thanks.
My mistake, the Data In property is available.
Looks like I can achieve what I need with the following:
dataOut = event.source.parent.getComponent('Row Selector').dataOut
dataIn = event.source.parent.getComponent('Row Selector').dataIn
if dataOut.rowCount==dataIn.rowCount:
filename = "All"
else:
filename = dataOut.getValueAt(0,0)
system.gui.messageBox(filename)
