When using a row selector how should the shift filter be used when the shift starts at 19:00 and runs until 07:00 the next day, is this possible?
Any luck on this one??
If you set up a night shift say 19:01 to 06:59 it won’t cross the 23:59 t stamp.
Unfortunately the Row Selector’s ‘Shift’ filter doesn’t allow you to span days. You can split the overnight shift in two and give them both the same name. ie: night 00:00-08:00
day 08:00-20:00
night 20:00-23:59
