Can someone help?
I have multiple Ignition projects in the computer. I need to gun them onto different displays. I have multiple displays connected to my computer.
How can I project one Ignition project to a specific display for running?
Lei
Can someone help?
Lei
Vision or perspective?
Vision.
You're looking for system.gui.openDesktop() then
Hi, I am a newbie with Ignition.
How do I do it exactly, like where I use system.gui.openDesktop() in a project?
I highly recommend going through the free courses on www.inductiveuniversity.com.
Typically in Vision, one of your windows will Open on Startup which will have a little play button, like ►, beside it. Right click on it and disable the open on startup window function.
Then open Vision → Client Events and put the openDesktop() script in the Startup event.
I would like to further my questions.
I have several HMI projects run on the same Ignition gateway. I would like to project each HMI project onto different monitors. How do I do it?
The issue to use system.gui.openDesktop() in this case, is that seems every time I switch screen I need to run a script to make sue it goes to a right monitor.
Thanks in advance.
I don't know you're full requirements. I gather that you might have 4 screens that will have 4 different projects, one per screen. Each project will have a start up script to open on the correct screen using openDesktop. The script will only run once, on startup, per project. Does this not fit your use case?
