Hi all,
I cannot figure out why this script fails. I have restarted Designer with the same results.
From the Script Console…
The binder_select_index query works and has a matching parameter and the commented section works as expected.
What am I missing?
Thanks, Steven
In the script console screenshot: line 2 (end of the line) binder_name parameter should be binder perhaps.
I think you might have flipped the dictionary parameter with it’s value
try
binder = "another binder"
binder_id = system.db.runNamedQuery("binder_select_index", {"binder_name":binder})
@ryan.white & @code_skin,
That’s it!!! I was looking at the parameter definition backwards!!
Thanks for your help!!
Steven
