I have a script project that I’m running from a simple button by using the following line
project.EmailReport_Generator.machine(‘Machine1’) and works fine.
Now I want to run that script 3 times a day.
So I try do it from the tag change on the gateway event script but I got an error and I think is because my actual script has some ‘gui’ commands. And I tried the client event scripts using the same tag change feature, but seems to me like is not running it.
So I wonder if there is a way to use an expression item in my transaction group that I can use to run my script 3 times a day.
Thanks in advance.
