Hi, I am running a ignition edge as a docker container on a azure VM. It is working fine. I want to install ignition designer on same virtual machine. I am bit stuck on that. Can you please guide?
I'm not familiar with Ignition Edge, but can you not go to the home page on the gateway and download the designer?
If you're running Ignition in a container on a [Linux] Azure VM, do you have a GUI to run the Designer from there? The typical use case would be to run the Designer on your client OS (locally) and connect it to your Ignition gateway (Azure). @Ryan_Allen is correct in that you can download the Designer Launcher from the Ignition Gateway webpage that can then be used to launch the Designer (against Ignition running in your Azure VM).
