Running Script on Standard Gateway Triggered by Tag Events in Remote Edge Gateway
Hi everyone,
I’m working with a distributed Ignition setup where:
Edge Gateway collects data from PLCs and triggers tag events
Standard Gateway handles logic like API calls and external integrations
The Edge Gateway is connected as a remote tag provider to the Standard Gateway
Goal:
When a tag (e.g., alarm or dataset) changes on the Edge Gateway, I want to:
Detect that event (e.g., in a valueChanged script)
Trigger a Python function defined on the Standard Gateway (not Edge)
Keep all external logic centralized in the Standard Gateway
Questions:
1.Is it possible to trigger a script on the Standard Gateway from a tag event on Edge?
2.Is system.util.sendMessage() from Edge to Standard the correct/recommended approach?
3.Can this scale well if multiple Edge gateways are sending data to one Standard?
Any guidance or patterns appreciated. Thanks in advance!
  1. No, not directly.
  2. Yes, or system.util.sendRequest() if Edge needs a reply.
  3. Should scale OK, but not great. Will require some logic on Edge to deal with comms breakage in a custom fashion. There's no Store and Forward for messaging.
Thanks, pturmel that clears it up!
Good to know system.util.sendMessage() is the right path, and I’ll look into sendRequest() as well since I may eventually want confirmation or results back.
Also appreciate the heads-up about messaging not having Store and Forward.
I hadn’t considered comms failure handling yet, so I’ll plan to add some retry or logging logic on the Edge side.
Much appreciated!
