We have been running Ignition 7.7.7 in production and testing 7.7.8.
We use modules developed using SDK, earlier we used to upload unsigned modules to Inductive’s website get them signed and now we are using module signer tool to sign modules.
I tried signing the module using Self-Generated certificate for testing, i observed that i could load this module to 7.7.8 but not to 7.7.7. I ran into below errors while trying to upload. Any suggestions would be appreciated.
com.inductiveautomation.ignition.gateway.modules.ModuleVerificationException: Module signature not present.
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.verifyModuleSignatures(ModuleManagerImpl.java:1627)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.loadModule(ModuleManagerImpl.java:1509)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$4.call(ModuleManagerImpl.java:954)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:1095)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModuleInternal(ModuleManagerImpl.java:936)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.access$1500(ModuleManagerImpl.java:122)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$InstallCommand.execute(ModuleManagerImpl.java:1825)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1766)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:45)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:658)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:678)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:537)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
