Running Vision on windows embedded standard 32 bit service pack 1
I would like to run a very simple vision project on windows embedded standard 32 bit SP1. The vision client launcher installer does not run on this version of windows.
Is there a way to install/run vision on this operating system?
You'll probably have to go back a few versions to find that type of installer:
Support for Windows 32-bit was dropped starting at 8.0.
There's a bit of a workaround you can use to launch a client directly if you can provide your own 32-bit JDK.
