runPrepQuery giving strange error, SQL command not properly ended
Code is executed from an system.util.invokeAsynchronous() (gateway scope).
Code
current_data = system.tag.readBlocking([
	"[UNS]Machine01/Room01/Tag1",
	"[UNS]Machine01/Room01/Tag2"
query = """
	SELECT op.operationid FROM operations op
	INNER JOIN operations_steps st
	ON op.operationid = st.operationid
	WHERE op.workorderid = ?
	    AND JSON_VALUE(op.context,  '$.iteration') = ?
	    AND st.step = 7;
step_exist = system.db.runPrepQuery(
	query,
		current_data[0].value,
		current_data[1].value
	"DB"
I tested the query in the database and worked without problem. For some reason whenever I use the runPrepQuery it doesn't work.
The error says "Command not properly ended"???
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: ORA-00933: SQL command not properly ended
I know I'm missing something because I used these type of queries before...
Thanks in advance!
Drop the semicolon, perhaps? JDBC expects single statements, so a statement divider should not be necessary.
You were right, you are totally right. Thx!
