runPrepUpdate puzzle
This query works in MySQL Workbench.
INSERT INTO manf_dashboard.production_log
			(machineId, event, cycleCount, goodCount, sku, runstatus)
			VALUES ('Delete', 'test', 44, 33, 'Dummy', 0)
It fails in Designer Script Console
query = """INSERT INTO manf_dashboard.production_log
			VALUES ('Delete', 'test', 44, 33, 'Dummy', 0)"""
system.db.runPrepUpdate(query, [])
Java Traceback
Java Traceback:
  File "<input>", line 63, in <module>
			VALUES ('Delete', 'test', 44, 33, 'Dummy', 0), [], , , false, false)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:268)
	at jdk.internal.reflect.GeneratedMethodAccessor52.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO manf_dashboard.production_log
	at org.python.core.Py.JavaError(Py.java:547)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:552)
	at org.python.core.PyObject.__call__(PyObject.java:477)
	at org.python.core.PyObject.__call__(PyObject.java:481)
	at org.python.pycode._pyx70.f$0(<input>:63)
	at org.python.pycode._pyx70.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1687)
	at org.python.core.Py.exec(Py.java:1731)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:626)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:614)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO manf_dashboard.production_log
	... 25 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:384)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:288)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:261)
	... 23 more
I've checked the database connection using the select query below and it works.
system.db.runQuery("SELECT * FROM manf_dashboard.production_log LIMIT 10")
Can anyone suggest some further checks for me to narrow down the cause of the problem?
Many thanks.
Set your designer to read/write mode. (Yes, the same setting for tags impacts legacy DB script functions.)
