I am trying to use the runScript() function as the expression defining a tag value. I get this error (sent to you in full).
Error parsing expression: Parse error: Function 'runScript' is not defined.
What’s up? Can I use this function here?
Nope, you can’t use runScript() in a tag expression. SQLTag expressions are evaluated by FactorySQL - which doesn’t have the Jython scripting engine.
Here’s the script I want to execute.
power = some polynomial using a single input value WS
if WS is less than 4: power = 0.0
if WS is greater than 25: power = 0.0
I can probably figure out embedded ‘if’ statements to do this in a tag, but is there a cleaner way that you can think of? Will ‘if’ statements work here?
Thanks.
I think its just an expression like this:
if ({WS} < 4 || {WS} > 25, 0.0, polynomialOfWS)
Indeed. Thanks.
