I am trying to use the runscript function in an expression tag.
I tried running the script from the script console and also made a new function with no parameters with a return of 1 just to text that the parameters weren’t wrong.
This is happening to all our runscripts that worked previously in 7.9 and 7.10
Is this an upgrade or piecemeal import?
Is the Gateway Scripting Project set to the project that contains those scripts?
It was imported.
That setting was blank I will change it and see if that fixes things
The gatewat scripting project fixed the issue.
Thank you.
