Runtime Performance Is Too Slow
I have multiple screens with multiple equipment's have individual faceplates. and it started lagging and have very slow response.
What are the specs of your server, looks like only 3GB of RAM, not a huge amount if multiple devices and clients.
Thank you for your response.
I Try to increase the Ram Up to 8GB Still Facing the Same Issue
Vision or perspective?
If vision the problem is almost certainly not the gateway but inefficient scripting at the client level.
Edit
Can you also provide more information about your system as a whole? What PLC, what architecture etc?
The memory isn't the issue. You are way lower than 8GB so there is something else going on.
I am using perspective Scada That too In Virtual Machine.
Specifications Of VM: -
13th Gen Intel(R) Core (TM) i7-1365U 2.69GHZ (4 Processors)
RAM: -12 GB
System: - 64-Bit
Using Rockwell PLC on Emulator and Getting Data Through RS Linx
What does your device connection status look like for the Emulator Connection? Can you provide a screen shot?
