Thanks for the link, I did look at the post but I’m not sure if I can take that approach here. I have restrictions where the time ranges have to look like the large strings I have circled.
Here is working code from one of the text fields where monday_setup and tuesday_setup are my long string properties that are copied from the monday and tuesday string values from the db:
if event.propertyName == 'text':
	def timeRangeBreakup(rangeStr, delimiter):
		componentList = []
		lastBreak = 0
		for i in range(len(rangeStr)):
			if rangeStr[i] == delimiter:
				componentList.append(rangeStr[lastBreak: i])
				lastBreak = i + 1
			if i == len(rangeStr)-1:
				componentList.append(rangeStr[lastBreak:len(rangeStr)].strip())
		return componentList
	event.source.parent.getComponent('select_shift 1').visible = 0
	rangesStrSetup = event.source.parent.monday_setup
	nextDayRangesStrSetup = event.source.parent.tuesday_setup
	try:
		rangeStr = event.source.text
		time = timeRangeBreakup(rangeStr, '-')
		start = time[0]
		startComponents = timeRangeBreakup(start,':')
		startRightSideTime = timeRangeBreakup(startComponents[1],' ')
		startMinute = int(startRightSideTime[0])
		startAMPM = startRightSideTime[1]
		if startAMPM.startswith('A'):
			startHour = int(startComponents[0])
		else:
			startHour = int(startComponents[0]) + 12
		end = time[1]
		endComponents = timeRangeBreakup(end,':')
		endRightSideTime = timeRangeBreakup(endComponents[1],' ')
		endMinute = int(endRightSideTime[0])
		endAMPM = endRightSideTime[1]
		if endAMPM.startswith('A'):
			endHour = int(endComponents[0])
		else:
			endHour = int(endComponents[0]) + 12
	except:
		startHour = 23
		startMinute = 58
		endHour = 23
		endMinute = 59
	nextDayActive = 0
	nextDayStartHour = 0
	nextDayStartMinute = 0
	nextDayEndHour = 0
	nextDayEndMinute = 0
	if startHour >= endHour:
		if startMinute > endMinute:
			#Range goes past midnight
			nextDayActive = 1
			nextDayEndHour = endHour
			nextDayEndMinute = endMinute
			endHour = 23
			endMinute = 59
	now = system.date.now()
	startDate = system.date.setTime(now,startHour,startMinute,0)
	endDate = system.date.setTime(now,endHour,endMinute,0)
	tomorrow = system.date.addDays(now,1)
	nextDayStartDate = system.date.setTime(tomorrow,nextDayStartHour,nextDayStartMinute,0)
	nextDayEndDate = system.date.setTime(tomorrow,nextDayEndHour,nextDayEndMinute,0)
	overlap = False
	nextDayOverlap = False
	if len(rangesStrSetup) > 0:
		ranges = timeRangeBreakup(rangesStrSetup,',')
		for i in ranges:
			time = timeRangeBreakup(i,'-')
			start = time[0]
			startHourSetup = int(startComponents[0])
			startMinuteSetup = int(startComponents[1])
			startDateSetup = system.date.setTime(system.date.now(),startHourSetup,startMinuteSetup,0)
			end = time[1]
			endHourSetup = int(endComponents[0])
			endMinuteSetup = int(endComponents[1])
			endDateSetup = system.date.setTime(system.date.now(),endHourSetup,endMinuteSetup,0)
			if (system.date.isBetween(startDate,startDateSetup,endDateSetup) or
				 system.date.isBetween(endDate,startDateSetup,endDateSetup) or
				 system.date.isBetween(startDateSetup,startDate,endDate) or
				 system.date.isBetween(endDateSetup,startDate,endDate)):
				overlap = True
				break
	if nextDayActive:
		if len(nextDayRangesStrSetup) > 0:
			nextDayRanges = timeRangeBreakup(nextDayRangesStrSetup,',')
			for i in nextDayRanges:
				start = time[0]
				nextDayStartHourSetup = int(startComponents[0])
				nextDayStartMinuteSetup = int(startComponents[1])
				nextDayStartDateSetup = system.date.setTime(tomorrow,nextDayStartHourSetup,nextDayStartMinuteSetup,0)
				end = time[1]
				nextDayEndHourSetup = int(endComponents[0])
				nextDayEndMinuteSetup = int(endComponents[1])
				nextDayEndDateSetup = system.date.setTime(tomorrow,nextDayEndHourSetup,nextDayEndMinuteSetup,0)
				if (system.date.isBetween(nextDayStartDate,nextDayStartDateSetup,nextDayEndDateSetup) or
					 system.date.isBetween(nextDayEndDate,nextDayStartDateSetup,nextDayEndDateSetup) or
					 system.date.isBetween(nextDayStartDateSetup,nextDayStartDate,nextDayEndDate) or
					 system.date.isBetween(nextDayEndDateSetup,nextDayStartDate,nextDayEndDate)):
					nextDayOverlap = True
					break
	formatStartTimeHH = system.date.format(startDate,"HH:mm")
	formatEndTimeHH = system.date.format(endDate,"HH:mm")
	formatStartTimehh = system.date.format(startDate,"hh:mm a")
	formatEndTimehh = system.date.format(endDate,"hh:mm a")
	timeRangeHH = formatStartTimeHH + ' - ' + formatEndTimeHH
	timeRangehh = formatStartTimehh + ' - ' + formatEndTimehh
	nextDayFormatStartTimeHH = system.date.format(nextDayStartDate,"HH:mm")
	nextDayFormatEndTimeHH = system.date.format(nextDayEndDate,"HH:mm")
	nextDayFormatStartTimehh = system.date.format(nextDayStartDate,"hh:mm a")
	nextDayFormatEndTimehh = system.date.format(nextDayEndDate,"hh:mm a")
	nextDayTimeRangeHH = nextDayFormatStartTimeHH + ' - ' + nextDayFormatEndTimeHH
	nextDayTimeRangehh = nextDayFormatStartTimehh + ' - ' + nextDayFormatEndTimehh
	if rangeStr is not None and len(rangeStr) > 0:
		if overlap == False and nextDayOverlap == False:
				rangesStr = rangesStrSetup + ' , ' + timeRangeHH
			else:
				rangesStr = timeRangeHH
			event.source.parent.monday_setup = rangesStr
			if nextDayActive:
					nextDayRangesStr = nextDayRangesStrSetup + ' , ' + nextDayTimeRangeHH
				else:
					nextDayRangesStr = nextDayTimeRangeHH
				event.source.parent.tuesday_setup = nextDayRangesStr
			event.source.parent.refresh = True
		else:
			if overlap:
				event.source.parent.getComponent('tf 1').nonEditableBackground = system.gui.color(255,0,0)
			if nextDayOverlap:
				1
				#system.gui.messageBox('This entry does not fit the schedule','Overlaps next day')
	else:
		daySetup = event.source.parent.monday_setup
		ranges = timeRangeBreakup(daySetup, ',')
		print ranges
		loopCount = 0
		newList = ''
		for i in ranges:
			if loopCount == 0:
				newList = i
			elif loopCount == 1:
				newList = newList + ' , ' + i
			elif loopCount == 2:
			loopCount += 1
		event.source.parent.monday_setup = newList
		#How to remove the corresponding item from the next day for shift 3?
