Running Ignition 8.1.16 with Vision. Have 2 DB tables. One successfully runs this query from script but the other one errors for a reason I do not know.
works:
if globalVars.logger:
#get today's date
date = system.date.format(system.date.now(),"yyyy_MM_dd")
#select rows older than 3 months
chemSelectStatement = "SELECT t_stamp, chem_code, chemMeter_val, chemPump_val, conc_str, meter_val, pump_val, sample_str FROM Chem WHERE t_stamp < DATEADD(MONTH, -"+str(globalVars.chemTrendAge)+", CURRENT_TIMESTAMP)"
#select the data
chemDataToDrop = system.db.runQuery(chemSelectStatement, "AppDataLog")
#delete records
deleteChem = "DELETE FROM Chem WHERE t_stamp < DATEADD(MONTH, -"+str(globalVars.chemTrendAge)+", CURRENT_TIMESTAMP)"
system.db.runUpdateQuery(deleteChem,"AppDataLog")
errors:
#get today's date
#delete records
deleteData = "DELETE FROM Data WHERE t_stamp < DATEADD(MONTH, -"+str(globalVars.dataTrendAge)+", CURRENT_TIMESTAMP)"
system.db.runUpdateQuery(deleteData,"AppDataLog")
Error:
Java Traceback:
File "<input>", line 5, in <module>
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:188)
java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(DELETE FROM Data WHERE t_stamp < DATEADD(MONTH, -3, CURRENT_TIMESTAMP), AppDataLog, , false)
at org.python.core.Py.JavaError(Py.java:547)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:541)
at org.python.core.PyObject.__call__(PyObject.java:477)
at org.python.core.PyObject.__call__(PyObject.java:481)
at org.python.pycode._pyx59.f$0(<input>:5)
at org.python.pycode._pyx59.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1687)
at org.python.core.Py.exec(Py.java:1731)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:611)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:599)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runUpdateQuery(DELETE FROM Data WHERE t_stamp < DATEADD(MONTH, -3, CURRENT_TIMESTAMP), AppDataLog, , false)
... 26 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:384)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runUpdateQuery(ClientDBUtilities.java:262)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:181)
... 24 more
Data DB table format:
