I need to write a boolean value to the tag but I don’t know how.
Could you give me a sample so that I can write a boolean value to my PLC?
If I should use this function, could you give me a sample?
system.tag.writeToTag
Regards.
Regards.
system.tag.write("tagpath",True)
Thanks, now I’m can enable other tag. The problem is that keeps in true. I need to get a kind of feedback of this tag that I’m using the code below.
Please, Check the code bellow.
I need that the code: system.tag.write("[BRA_POSTPRESS]BRA_BUNDLE/LOWER_LINE/gDataLabelerA", True), give me a status of this variable that I’m using and not set this value.
Do you have some sugestion?
import system
# we acquire a logger
logger = system.util.getLogger("LBL_A_SendLabel.Tag.Change.Script")
logger.debug("Starting Tag Change Script")
if currentValue.value == 1 and not initialChange:
barcode = system.tag.read("[BRA_POSTPRESS]BRA_CALCULATED/LABELS/LOWER_LINE/BARCODE")
barcode = barcode.value
name = system.tag.read("[BRA_POSTPRESS]BRA_CALCULATED/LABELS/LOWER_LINE/PRODUCT_NAME")
name = name.value
bundle = system.tag.read("[BRA_POSTPRESS]BRA_CALCULATED/LABELS/LOWER_LINE/STACKS_PER_BUNDLE")
bundle = bundle.value
size = system.tag.read("[BRA_POSTPRESS]BRA_KL540_LL/copys_bundle")
size = size.value
produced = system.tag.read("[BRA_POSTPRESS]BRA_BUNDLE/LOWER_LINE/BundleCounter")
produced = produced.value
date = system.tag.read("[BRA_POSTPRESS]BRA_SYSTEM/OPC_TimeStamp")
date = date.value
weight = system.tag.read("[BRA_POSTPRESS]BRA_CALCULATED/LABELS/LOWER_LINE/WEIGHT")
weight = weight.value
expected = system.tag.read("[BRA_POSTPRESS]BRA_CALCULATED/LABELS/LOWER_LINE/TOTAL_BUNDLES")
expected = expected.value
data = shared.CONSTANTS.label.generic(barcode,name,bundle,size,produced,date,weight,expected)
'''filename = system.file.getTempFile("txt")
system.file.writeFile(filename, data)'''
a_auto = system.tag.read("[BRA_POSTPRESS]BRA_BUNDLE/LOWER_LINE/Label_Aire_A_Auto")
a_start = system.tag.read("[BRA_POSTPRESS]BRA_BUNDLE/LOWER_LINE/Label_Aire_A_Start")
a_online = a_auto.value and a_start.value
if a_online == 1:
I think your problem is here:
(and all the other instances of system.tag.read).
system.tag.read() returns an object. You need to add “.value” to the end of the call to pull the value out of the resulting object.
