Sample_Tags: Bad_NotConnected
I have a error with Sample_Tags (Bad_NotConnected) and the status for Ignition OPC is FAULTED
So thats not a problem with the tags but with te connection.
Why does it say its faulted?
Is the password correct?
https://docs.inductiveautomation.com/display/DOC81/OPC+UA+Server+Settings
I use the default OPC connections, I didn’t change anything in the settings :
Default Credentials
Ignition's OPC UA server does not initially support anonymous access, but can be configured to do so (see the settings table below). Authenticated connection require the following credentials:
Username opcuauser
Password password
as lisited on https://docs.inductiveautomation.com/display/DOC81/OPC+UA+Server+Settings
You or somebody else certainly did change something because the default username is “opcuauser”, not “user”.
I changed its settings but still does not work
Username opcuauser
Password password
you’ll have to show us the details of the server status and why its faulted
