Sap to ignition integration
SAP needs to be integrated with ignition . Defined a webdev Get url in ignition , so that sap can fetch token for basic authentication and post the production loads into another post url , Although all configs are correct along with users,roles. still getting 401 unathorized error in sap . can anybody advice?
You'll need to provide a lot more information for anyone to be able to help you.
Show your scripts that you are using to attempt to communicate with SAP. What do the payloads you are sending to Ignition look like? Provide examples of your attempts (with sensitive information redacted as necessary). Are there any errors in your gateway logs that line up with failed attempts?
Post code and payloads as preformatted text to aid with viewing and troubleshooting, see Wiki - how to post code on this forum.
