wking
January 25, 2021, 4:03am
1
I switched from a Windows server to a Linux server.
I used to be able to save to the share drive with a path like this…With save actions using the reporting module.
\is-everyone\DP\MES System\Data Dumps\Production Planning
I tried with forward slashes and different combos of double slashes. But, I seen it’s creating the directories inside of /usr/local/bin/ignition/
What am I missing. I can see the drive @ is-shareshop
You will definitely need forward slashes. Not sure how your share is set up, but I recommend mounting it.
In a similar situation, I had to use mount to properly get a share to work. The share I was connecting to had an everyone type access, but I still had to put in a blank password.
sudo mount -t cifs -o password=,vers=1.0 //{redacted}/dswatch /mnt/dswatch
Probably ought to go in your fstab to always be mounted.
wking
January 25, 2021, 7:34pm
4
Turns out it is an AFP share drive.
And it’s proving to be a huge PITA to get it mounted. using afpfs-ng 0.8.1
https://sites.google.com/site/alexthepuffin/
Between this and the printers. I wish I would’ve just installed windows on my new server lol
Linux is only better if your time isn’t worth anything lol
Ooh, them's fightin' words
Yup. I figure I'm about twice as productive on Linux as on Windows. Largely due to absurdly flexible networking.
wking
January 25, 2021, 8:14pm
7
paul-griffith:
Ill get over it as soon as I can save to this drive
wking
January 25, 2021, 8:52pm
8
Was able to get mounted
to
/media/is-everybody/
When I try and save…any ideas? I did chmod 777 on /media/is-everybody
wking
January 26, 2021, 5:58pm
9
sudo mount -t cifs -o uid=1000,gid=1000,vers=1.0 //{IP-ADRESS}/dp /home/dp/pdrive2 -w
To get ignition to save to the drive. I had to mount the drive like so. I also had to use the IP address instead of a hostname.
pturmel
January 26, 2021, 7:32pm
10
That suggests that the root_squash functionality was the barrier--are you running Ignition as root? (Don't do that!)
So DNS isn't consistent, either. /:
I think ActiveX is the perfect example of how to save development time with Microsoft
There’s a learning curve but it’s not as bad as people make it out to be. On the other side of the curve is a huge ROI for your time if you do any sort of development imo
wking
January 26, 2021, 8:10pm
12
pturmel:
Ignition as root?
I don't think so? But, honestly I don't even know how to tell. lol
wking
January 26, 2021, 8:12pm
13
chasondeshotel:
with Microsoft
Now that my sharedrive access and TSC printers are back online. I formally retract those statements about Linux. Heat of the moment words.
Oh yea, I understand. The key to getting Linux support is to say “Windows does this, why can’t Linux?” and us Linux nerds pop out of the woodwork
