I’m using the system.file.saveFile to save a file to a location on the server. It already returns the file path but is there a way to pull out what the user typed for a file name?
openFilePath = system.file.openFile()
fileSaveTarget = system.file.saveFile(openFilePath)
docName = fileSaveTarget
compID = event.source.parent.getComponent('tblCompList').comp_id
pathID = 1
dwgTable = event.source.parent.getComponent('tblDwgList')
compTable = event.source.parent.getComponent('tblCompList')
docTable = event.source.parent.getComponent('tblDocuments')
if openFilePath != None:
bytes = system.file.readFileAsBytes(openFilePath)
system.file.writeFile(fileSaveTarget, bytes)
system.db.runPrepUpdate("INSERT INTO doc_list (doc_name, comp_id, path_id) VALUES (?,?,?)", [docName, compID, pathID])
system.db.refresh(docTable, "data")
system.gui.messageBox("Saved")
What I’m doing is allowing the user to pick a file they what to tie to a record in the database and then store the file in a different location on the server and we are managing the file paths. I know this can be done by creating a BLOB data type but that option doesn’t work for how this project has to be setup.
