Save history tag Ignition Edge
Hello, I need help to save the history tag of Ignition Edge into SQL. I already connect Ignition Edge to a central gateway, but I am missing some steps to do that. Could someone guide me in this missing steps that I am skipping, please?
Connection to Ignition Edge
Ignition Edge (Tag history)
Configuration Ignition Central Gateway (Tags)
If you want to save your Edge tag's history into your central gateway's database, you're gonna need Edge Sync Services, which is a plugin on your Ignition Edge License. To setup sync services you should consult this page in the user manual, Edge Sync Services - Ignition User Manual 8.1 - Ignition Documentation
