I am using Ad Hoc Trends in my Perspective project and was wondering if there is a way to set the default save location and open location for saving/reloading Trend configuration files to/from a folder? Currently when you press the save button or browse button the popup opens to a default location each time and I would like to change that default location to a specific folder for trends.
It is a browser. You have no control over local file locations (for very good security reasons). If you really need unrestricted local file operations, you would have to stay with Vision.
I just did a quick search, and Edge, Chrome and Safari all allow you to change the location of the “default location” used for saving files. I assume that other browsers also allow you to do this.
Instructions for changing Chrome default location
Right. They pretty much all do. But it is a browser setting that applies to all sites. Not a setting in your Perspective project that would apply just to your project.
Based on the OPs description, just changing the browser default would be sufficient
@steven.gyllich, should consideration be give to saving the configurations be saved on the server? This might require saving the configurations attached to a username, etc.
