Everytime i go to save a window, even if its unedited, the either the windows dimensions change, or some of the components get moved around. Why is this, and how do i cause it to stop?
I think you’ve run across a bug that we’ve recently become aware of. Could you please describe the window that this occurs in, specifically the value of the Dock position, Border Display Policy, and Titlebar Display policy properties?
Thanks for your patience, we appologize for the inconvenience,
Thanks for the quick reply Carl and for the help over the phone. I hope we can get this issue resolved with the next release
The issue has been fixed, and the fix will be released in the next version.
As a workaround, if you work on one window at a time, all should be fine.
Thanks,
