I have a base64 string that I turn into a BufferedImage using ImageIO
Before manipulating it, I want to save to a local drive.
from javax.imageio import ImageIO
from java.io import File
file_name = "E:\\" + name + "_image.jpeg"
outputFile = File(filename)
ImageIO.write(image, "jpeg", outputFile)
When I run it via the script console on Ignition, it writes to the drive with no errors. However when I have it on a script and run it, the image does not write. The rest of the program runs and does not stop at this step.
Does anyone know why it would work in script console but not as ignition script?
