I was wondering if there is the possibility to scale all windows in an Ignition project so that every component on the screen fits well? Because now it depends on one screen size
Thanks a lot!
Thanks a lot!
not sure if this will work, but worth a try.
select all the objects in your window, right click and select layout.
I think, by default it’s selected “Anchored” and it will not scale your window objects if there is a difference in screen sizes.
You can try to play around with the settings here.
